| Off-Topic Talk about anything other than cars. |
1g AWD mods
Ok im looking at a 1g awd talon
for the first round of mods im thinking boost gauge mechanical boost controller new intake pipe turbo outlet pipe KN filter the new intercooler pipeing 2.5" downpipe test pipe 3" exhaust remove that silencer thingy from behind the MAF symborski shift kit (i think i spelt it wrong) now I'll just adjust the boost controller for about 15psi. Did i miss anything before i start fuel upgrades. How much power will i be makeing?? any ideas on 1/4 times? |
I forot blowoff valve. any ideas on a good one thats not to pricey?
You should rewire your fuel pump if you want to run 15psi, just to be safe.
Dont bother getting a BOV, sure it sounds cool, but it desn't do anything for performance, or gas mileage, and you'll have cool black smoke come out your muffler when you shift Check out these links for more info on DSM's http://1000q.dsm.org/ http://www.vfaq.com/ http://www.dsm.org/
Chris Clark www.Talon007.com 1990 Eagle Talon TSi AWD - In Progress 1993 Eagle Talon TSi AWD - Parts Car 1990 Eagle Talon ESi - Sold 1-800-VFAQ - Bookmark it, read it, use it __________________ |
And I'd say START with the fuel upgrades. Save you lots of grief on the motor later. At least do the Stevetek fuel line upgrade first http://www.stevetek.com/R-FuelSys.html The 1G cars are close to maxxed out on fuel capacity as it is , trust me. The most boost you could prolly safely run is 15 psi on the stock fuel lines. Change the lines and you could run 19 psi or better. Lotsa people try to push the Walbro 255 fuel pump , but extra pump capacity won't fix deficient fuel lines. Otherwise sounds like a good upgrade path.
'90 Galant GSX , AWD , 5spd. Waiting on an engine swap. '03 WRX wagon , AWD , 5spd. Waiting on a paycheck.
3" pipe is the way to go if you want to get a bigger turbo later. I've read of DSM'ers in the 11's (drag racing) with the stock 14B turbo , so you are safe for a while on the turbo issue. You may wish to port the outlet housing and get RRE's(Road Race Engineering .com) outlet pipe , that'll remove a big kink in the air line. At this point all you really need is a boost guage. The Autometer Air/Fuel ratio guage is a nice blinky-light toy , but rather hopeless from a tuning view. You also won't need a S-AFC til you start hacking the MAF or swapping injector sizes. If you really want a manual boost controller , thats fine , but I personally like the Greddy Profec-B . It has 2 boost settings , so you don't have to waste time dialing in the MBC all day if you just wanna drive around town. The Profec-B has a high and low boost setting , that you can preset and forget , just hit the switch when you wanna change it. Neat stuff. You may also wish to port the stock wastegate housing , the stock size is hopelessly small for high boost (15+psi) and most of the time is cracked even from stock useage. I'd yank it and check it , port it if its not cracked , replace it otherwise or swap it for the 7cm housing (16G) Definitely make friends with the local DSM club , make sure its a DSM.ORG club and not just a ricer club. Local clubs can have great deals on parts and labor with local shops , it goes a long way , beleive me.Otherwise , good luck.
Yeah i think i might look into that Greddy controller. I plan on going up to the 16g eventually. I was wondering what is the most boost i can run on engine internals
Check out http://www.buschurracing.com/stage_1.html & http://www.buschurracing.com/stage_3.html I don't see any recommendations on upgraded fuel lines. Rob
"Got car lenghts?" or "You can turbo anything but can't make stupid people smart, something wrong with this picture?" |
Its been factually proven that 1G DSM fuel lines are woefully small and cannot support fuel capacity for much less than 12's , and that with hellacious pump pressure. The Stevetek system has been proven to flow 7 lpm versus the stock systems 1.5 lpm capacity , and that with the stock pump. I suggest you stop bowing to Buschur , who obviously doesn't have a clue , and start paying attention to DSM'ers who have actually contributed to the almighty FAQ's.
Rob
Rob
I'm just specifying that as a warning. I personally melted pistons in 2 different engines , and traced the problem to inadequate fuel capacity. First engine I was using a 3000GT fuel pump as an upgrade , the second time was with a Walbro 255. It was AFTER this that I discovered the Stevetek line upgrade , and I would recommend it to anyone just starting out. It makes the margin of error on fuel tuning that much wider. If your friends can run 12's on the stock lines , more power to them. I personally prefer the safe route.
