Old 11-18-2018, 04:31 PM
roadbum roadbum is offline
S-10 non start problem
I've got a 2002 S-10 which up to this point has run fine. Drove it and parked it a couple days ago no I go out to start it and all it will do is turn over not even a catch. Battery is good, and like I said, I've had no problems with it. I looked over the wiring which from what I could see looks okay. There's a possibility it could be a circuit breaker or fuse however I have no idea which one if that's the case. But the thing that puzzles me is the truck ran fine one day now it won't even start
Old 11-18-2018, 06:40 PM
Blue Bowtie's Avatar
Registered Offender
Re: S-10 non start problem
Any circuit breakers used are auto-reset (thermal). Most of the system is fused.
When the ignition is first turned on (without cranking) can you hear the fuel pump run for about two seconds?
Can you remove the coil wire (easily accessible on the right side of the intake) and have an assistant crank it briefly to check for spark?
The Following User Says Thank You to Blue Bowtie For This Useful Post:
roadbum (11-18-2018)
Old 11-18-2018, 08:17 PM
Reply to Blue Bowtie; I'll give that a try tomorrow, and thanks for giving me a place to start When I crank it and there isn't even a catch My first thought is no spark. I'd just like to know why one day it's running fine then the next...nothing.
Old 11-25-2018, 08:36 AM
Tech II Tech II is offline
If spark is ok, spray carb cleaner into the intake and see if it starts....
Old 11-26-2018, 01:59 AM
brcidd's Avatar
brcidd brcidd is offline
If it starts with carb cleaner and stalls-- then Whoooooop the fuel tank (palm of your hand) while someone else is cranking the engine--this is dead give away that you need a fuel pump if it starts. Done this a dozen or more times in my life- lets you drive it home- and tells you what the issue is....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
