Go Back   Automotive Forums Car Chat > Cars in General
Old 11-11-2018, 08:30 AM
stream stream is offline
Unhappy bad smell my car is making sometimes
Smells like plastic is being burned - toxic odor
I am now using synthetic oil in my car that burns a little oil - hope that is all it is and not some wiring frying somewhere!
Old 11-14-2018, 10:06 PM
beepbeepph beepbeepph is offline
Re: bad smell my car is making sometimes
If the burning smell starts when you turn on your air conditioner the potential reason could be due to the dust is burning off, but it should go away within a few minutes. Another possible reason could be your air filter is clogged which causes a burning smell.
I would also suggest that you should visit your trusted auto shop to further check the situation as this might also cause by some short circuits or worn electrical connections to your car's system. Hope this helps!
Old 01-24-2019, 03:51 AM
ayazahmad ayazahmad is offline
Check your AC
Check your Air Filter
Check under the backseat if there is something wrong
Check the wiring
And in Last go to your auto mechanic
Tags
odor , oil , synthetic
