| Register | FAQ | Social Groups |
| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
2K clear users - which respirator do you use?
Question to those who use 2K clear, which respirators/masks do you use?
I can no longer get cartridges for my old 3M mask, so need to get something new - what does everyone uses these days?
The client is not always right. - Enzo Ferrari ItalianHorses.net ![]() ![]() ![]()
Re: 2K clear users - which respirator do you use?
I use the 3M 6200 mask with the black cartridge
Almeida... I'm back! |
I thought black cartridges do not filter organics? Iso is no joke man.
You need air fed apparently. If you read up on it, very little can be done to filter out the vapor and it's very very toxic
I was just wondering what everyones' setups were.
I stopped using 2k to be honest. I read up on it and decided it's not worth the risk. Apparently it can go through your skin, eyes all manner of things. So it's not just a mask you need. But also eye and skin protection..
Steve Noble |
If you use organic filters rated at P95 or P100, you are pretty safe. The question was mostly which masks people use, I didn't realize that not a lot of people use 2K chemicals.
I've sprayed 2k clears on automobiles. It's not all that bad as some here are trying to make it out to be. There is definitely no need for an air fed system for the little amount being used on a model.
As far as respirators Harbor Freight actually sells disposable respirators. They are good for several uses of painting a whole automobile so they would probably be good til it deteriorates painting something like a model.
Still the same. I won't use 2k unless I get a better set up because it only takes one inhalation (according to safety advice I read a long time ago) to give you permanent symptoms
When you guys use respirators, is that in addition to a spray booth? When I use 2k, I try to spray as close to the extraction fan as possible so that the overspray and fumes goes out the window. I also have a window fan running pretty much 24/7 to keep the room ventilated whether I'm painting or not. Its not 100% safe but I feel like the risk is reduced. What kind of set up is everyone using in addition to respirators?
Well, I spray outside, so proper ventilation is a non-issue for me.
| Thread Tools | |
