Old 10-31-2018, 03:37 PM
kevin23 kevin23 is offline
3 cyl diesel tractor
Tractor JD, is forcing coolant past radiator cap and out over flow tube. I suspect head gasket. Have changed cap, etc. Engine does not run hot in cooler fall temperatures , but will get very near the hot indicator in hot summer months. Thermostat is not the problem.
I know the correct repair is replace head gasket, but is any of the pour in head gasket sealers any good, Blue Devil is one that I have heard was a favorite.
Really appreciate comments. Don't want to make matters worse.
Old 10-31-2018, 07:40 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 3 cyl diesel tractor
I wouldn't use any pour in sealer. My cousin had also heard good things about Blue Devil and followed the instructions to a tee. He ended up replacing his entire cooling system as well as his head gasket as a result.
Old 11-02-2018, 04:00 PM
Thanks
