Old 08-28-2018, 06:56 PM
jamesmetairie jamesmetairie is offline
98 lumina,coolant leak on floor.=
coolant on driveway floor.==
small coolant leak. passenger side nearest to fire wall area. no coolant trail seen.
a few drops on the bottom corner of engine block.
mechanic says maybe it,s coming thru the timing chain cover.
will tighten the bolts.
thanks for any advice.
Old 08-28-2018, 09:25 PM
Tech II Tech II is offline
Re: 98 lumina,coolant leak on floor.=
If a coolant pressure test doesn't show the source, than add coolant dye and use a black light...
I am guessing a 3.4, and lower intakes are famous for leaking...
Old 08-28-2018, 09:27 PM
Blue Bowtie's Avatar
Registered Offender
It's possible that the TC cover is leaking. It's more probable that the corner of the intake or water pump would be a source.
Old 08-30-2018, 12:56 PM
my back yard mechanic replaced the water pump about 10 days(?) ago.. it had a residue around the seep hole so we figured that was it.
the manifold gasket was replaced years ago with a metal felpro.
car has about 280,000 miles on it now.
curious thing= I,ve been having vacuum problems for a while. wonder if there,s a connection to this coolant leak somehow?
