Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 08-21-2018, 12:22 AM
SteadyOn SteadyOn is offline
'76 Camaro turn signal problems.
Currently having a problem regarding the driver-side turn signal of a 1976 Camaro. As it now stands, only one of two filaments is receiving power. With parking/headlights off, the turn signal works as intended, though dim with a single filament. Turning on the parking/headlights causes the gauge cluster (wired correctly, already checked) to show constant power to the driver turn signal, but the filaments do not light up, nor does attempting to use the left-hand turn signal work. Turning on hazards causes only one filament to light up, the same one that works without parking lights on, and it flashes opposite of the right side signal, which works as intended with both filaments lighting up. Any help or ideas as to the cause and solution are greatly appreciated.
Thanks!
Old 08-21-2018, 06:09 AM
Blue Bowtie's Avatar
Registered Offender
Re: '76 Camaro turn signal problems.
Check/clean the ground for the lamp housing and socket.
Old 08-23-2018, 08:36 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Seconded, check the quality of your grounds.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
The Following User Says Thank You to silicon212 For This Useful Post:
CruAutomotive (01-03-2025)
Old 01-10-2024, 08:22 PM
Ol'Jim Ol'Jim is offline
Obviously an old thread, don't know how I missed it. Hopefully the O.P. found and corrected the cause of his problem, (which is often dirty or missing ground connections), as Blue Bowtie and Silicon 212 suggested.
For future reference, folks that may run into this issue - My son's car had the exact same problem, and we cleaned the sockets, ground connections, replaced all the bulbs, checked the wiring to the lamps... Wound up eventually replacing the turn signal switch assembly within the steering column. The replacement unit was from Classic Chevy Parts in Oklahoma City. Included the harness, and was a very well made reproduction part. Solved the problem for us.
-Jim
2015 Silverado Crew Cab 2500HD 6.6 Duramax 4x4
2002 Silverado Crewcab HD 2500 6.0 4x4 Sold 281K Great Truck
1970 Chevelle SS454 (Gave to my son 9 years ago for his 18th birthday. Yeah, I know, crazy, right? Thank goodness he doesn't drive it the way I would, -er, did...).
1971 Monte Carlo SS454 Drag Racer. The old girl finally got new paint!
1968 Camaro SS (New race car project). Caged, Tubbed, Back-Half/Ladder Bars. Rolling Chassis (For now).
Old 10-13-2024, 10:52 PM
Resiniann Resiniann is offline
Not the fact that it might have helped.
Tags
camaro
