Old 08-16-2018, 09:13 AM
sreilly77's Avatar
sreilly77 sreilly77 is offline
AFM & Throttle Response - Tuner??
Has anyone had experience with tuning their trucks to deactivate the AFM and increase throttle response? I can't stand the AFM on my 2016 5.3, especially while towing.
But my BIGGEST issue is throttle response. If I need to go WOT due to an emergency situation, or increasing throttle going up a hill, there is almost a 1/2 second delay before the engine responds. Hell, my '86 Thunderbird has better throttle response with a throttle cable setup, and that's only a measly V6!!
Any suggestions would be appreciated. I am happy with the power this truck has. I just want to do away with the AFM, and get better throttle response. Thanks!
Sean
Old 08-16-2018, 11:45 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: AFM & Throttle Response - Tuner??
You can deactivate cylinder shut down, but the only way to truly (and properly) get rid of it is a replacement cam and lifters. DBW throttle lag is somethimg many people just learn to live with though I am sure there is something you might be able to do to help.
Old 08-18-2018, 02:46 PM
j cAT j cAT is offline
[quote=sreilly77;7212262]
[quote]
*************** This is what to use .. reason they use it is because these AFM engines will fail with out this device.. plug and play.. then If you bring to dealership for some stuff un plug it .. also if you trade it in plug it in the other AFM GM truck or you can sell it on EBAY.https://rangetechnology.com/afm-disabler/
Old 08-20-2018, 07:12 AM
sreilly77's Avatar
Thanks, Stealthee. I'm not having oil burning issues as of yet, but I know it's inevitable based on the horror stories I hear and see. Just trying to be proactive so I don't fall into these same issues.
By the way, nice Stealth!
Sean
Old 08-20-2018, 07:13 AM
sreilly77's Avatar
[quote=j cAT;7212335][quote=sreilly77;7212262]
Thanks, j_Cat. Yeah, I've seen too many horror stories regarding the AFM. I'm not having the burning oil issue yet. However, it does seem to interfere while towing, and can cause a big BANG when downshifting uphill if its still in V4. I'm all about being preventative, and I need this truck to run over 250,000 miles like my last one did.
Sean
Old 08-20-2018, 08:00 AM
$200 for this AFM killer is expensive since that is all it does but better than a $7K engine replacement .many buy these day one not after it begins to do the oil burn then cam fail..
Old 08-23-2018, 07:38 AM
sreilly77's Avatar
Exactly. Thanks again!
Sean
Old 09-07-2018, 08:05 AM
did you get the AFM widget ? cheap insurance
