Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 08-16-2018, 12:47 AM
16penny 16penny is offline
94 b250 AC
ac works good on the norm setting but not on max it will blow hard for 30 seconds then its like a door closes and shuts the air flow off
Old 08-16-2018, 11:34 AM
alloro alloro is offline
Re: 94 b250 AC
There is a return vent on the passenger floor that is used when on Max AC...is it covered?
Old 08-16-2018, 08:36 PM
Re: 94 b250 AC
no sir I don't think so. the big vent in front of passengers feet is open
Old 08-17-2018, 10:42 AM
Re: 94 b250 AC
Well to me it sounds like something is clogging up that interior air return. When you switch to Max AC it closes off the outside air so that air is now mostly pulled from in the cabin. It would seem the duct for the outside air is passing air just fine which is why I'm focusing on that interior return air duct.
Old 08-18-2018, 10:55 AM
Re: 94 b250 AC
yesterday while driving I switched from norm to max ac and it was working until I had to accelerate then it shut off like before ill try and see what could be blocking it thanks
Old 08-19-2018, 09:41 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 94 b250 AC
Mode door movement while accelerating is most definitely a vacuum leak. 99% of time vacuum leaks are under hood at vacuum line source- usually rotted rubber or plastic tubing at intake manifold. trace your vacuum lines and determine where the problem is, and replace as necessary- Engine heat kills rubber and plastic lines over the years...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
