Old 08-14-2018, 01:27 PM
blk95lumina blk95lumina is offline
Bolt Specs & Thread Size for Front Hub and Speed Sensor
Hello,
Need to replace the front hub and front wheel speed sensor bolts on a 95 Lumina LS 3.1L w/ ABS.
Everything is rusted to the point at which a torch will be required.
Anyone know the specs for these bolts?
Thanks.
1995 Lumina LS Sedan 3.1L - 215K mi - Daily Driver
2002 Accord EX Sedan V-6 - 209K mi - Wife's Daily Driver
2000 Silverado LS RCSB 5.3L - 168K mi
Old 08-14-2018, 10:43 PM
Tech II Tech II is offline
Re: Bolt Specs & Thread Size for Front Hub and Speed Sensor
There are no speed sensor bolts....the sensor is part of the hub.
Just an axle nut, and 3-13mm bolts on the inside......these usually come with the new hub......
If specs are not in instructions in box, a place like Autozone can get you the specs online, especially if you buy it from them....or sign up with them, it's free, and you can look up the specs yourself....
Old 10-23-2019, 09:44 PM
Turns out I got everything apart without a torch, kept the same old hubs and bolts and been over a year now and everything is still going good. Still the original hubs. Had to take it all apart to replace the front axle seals. And the speed sensor actually did have a bolt and 2 alignment pins. That one bolt on the speed sensor took more time than any other b/c it was smaller and rusted the most. Still running the original CV axles too. Not a single tear in any of the boots.
