Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 08-11-2018, 11:55 PM
mike7ike mike7ike is offline
82 El Camino Carb Filter Fitment
I'm looking for an open element air filter for my 1982 V6 3.8L 231cid El Camino, everything I have found has a circular base but my carburetor has a weird semi-circle/trapezoid shape. I believe it is the stock carb but I'm not 100% sure. Here are some pictures of the carb. Any help is appreciated, Thanks!
(not quite sure how to add photos so hopefully one of these works)
Old 08-12-2018, 09:46 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 82 El Camino Carb Filter Fitment
The reason you're finding round filters is because you need a base that sits on the carb that the filter will rest on. Then a lid will sit on it. There is usually a stud that sticks out of the carb that the lid will slide over then you use wingnuts to secure it all together.
The Following User Says Thank You to Stealthee For This Useful Post:
mike7ike (08-12-2018)
Old 08-12-2018, 11:47 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
You will need to get an air cleaner for an E2ME carb, which is what is pictured. Easier said than done; this carb was a 'bastard carb' being the primary only section of a Quadrajet, and being fitted on vehicles from about 1978 to 1982 and usually on V6's or small V8s (i.e. 267 cubic inch).
There are no aftermarket air cleaners or filters for these that I am aware of.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
The Following User Says Thank You to silicon212 For This Useful Post:
Old 08-12-2018, 04:09 PM
Is there some sort of adapter that I need between the carb and base?
Old 08-12-2018, 05:43 PM
Stealthee's Avatar
If you can find the proper base then it sits right on the carb. It has the proper opening in the bottom to fit the carb.
Old 08-12-2018, 06:31 PM
its probably a bad idea but could I cut off the base of the stock filter and just get a new lid? I have access to welding supplies and metal working tools but I dont want to get dust in my engine. Thanks
Old 08-14-2018, 02:21 PM
brian_k24 brian_k24 is offline
Look up Mr. Gasket Dual Jet Air Cleaner Adapters 6400. Looks like it adapts a standard round air cleaner to the shape of your carb.
The Following User Says Thank You to brian_k24 For This Useful Post:
mike7ike (08-14-2018)
Old 08-14-2018, 11:16 PM
You are a lifesaver! Exactly what I need.
