Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-08-2018, 08:44 PM
tylershaw28 tylershaw28 is offline
07 Dodge 1500 5.7L hemi rebuild
Hey everyone, new to this site, when I was 16 I blew up this truck I have and am just getting around to rebuilding it. Looking for parts and need help finding them and tips for rebuilding, it didn’t have any oil in it and before I pulled the engine it still ran , just had this knocking noise that sounded like it traveled the crank because it would knock up and down, any help will be appreciated!
Old 08-11-2018, 02:14 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 07 Dodge 1500 5.7L hemi rebuild
Are you intent on building it yourself for the experience and high cost or are you open to getting a rebuilt and installing it yourself?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 08-14-2018, 08:30 AM
I’m paying for parts and I’m doing all the labor myself, it’s my first time doing anything like this and I’ve pulled the engine. It’s for experience and lower cost.
Old 08-14-2018, 07:49 PM
AF - Advisor
Have you located a machine shop to do the machining?
Are you boring and honing the block to be sure the cylinders are round and straight?
Are you going to face the valves, do the seats, setup the valve springs? What about the valves that the margins are too thin.....you'll have to replace the bad ones.
Don't buy pistons & rings until you find out how much it takes to clean up the cylinders.
Same with rod & main bearings until the crankshaft gets checked out.
Tags
1500 , 5.7l , dodge , hemi
