Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 07-30-2018, 04:46 PM
DrRadar DrRadar is offline
Just a guy
03 Explorer XLT: Bad master cylinder
147k miles. Just replaced all four rotors and pads: One of the front had worn through the pad material and the back of that rotor was gouging. The back pads were still thick -doesn't appear to have lost much/any material since I checked them 55k ago when I last did the front; wrote it off as the back wear more slowly than front.
But the pads looked glazed to me and I was concerned that the rotor was glazed too. Decided to replace rotors and pads...didn't want to wait to have the rotors resurfaced.
But I am concerned the master cylinder is bad because (1) the lack of wear on rear brakes; (2) spongy brake pedal when driving; and (3) the truck seems to "nose dive" when braking.
Is there a way to evaluate the rear brake operation and master cylinder with everything on the car? Or do I need to remove master cylinder to test it? What's best test method?
Thanks for any guidance.
Lloyd
18 Charger ScatPack 392
18 Lincoln Navigator L (Hers)
98 Grand Prix GTP Sedan (RIP)
99 Grand Prix GTP Coupe (to the moon)
05 Wrangler Unlimited (Junior's)
03 Explorer XLT (Sissy's)
Old 07-30-2018, 06:16 PM
aleekat aleekat is offline
Re: 03 Explorer XLT: Bad master cylinder
Before I would remove the master I would do a complete flush/bleed.
Post back, that's what makes Forums Work.
Old 08-01-2018, 10:00 PM
Just a guy
After changing rotors & pads, I removed as much old fluid from reservoir as I could, filled with new, and started bleeding. Refilled reservoir several times. I can't be certain that I got all the old fluid out, but I got a lot of it.
I failed to mention that when bleeding, the pedal went further down when bleeding the front than the back. I assumed this was normal behavior, but could it be indicative of a failed master cylinder?
Lloyd
