Old 07-03-2003, 09:04 PM
Xtreme Illusions Xtreme Illusions is offline
Send a message via AIM to Xtreme Illusions
need pix of vacuum hose's
I need a picture of vacuum hose's hooked up in a crx with a b16a1. For some reason the rex that i am working on has 2 solenoids braketed to the map sensor. I have taken one out and now have no clue on what to do with everything. I also don't know where to hook the solenoid up which ecu pin i mean. Any help would be greatly appreciated.
I also need help with wiring in the vehicle speed sensor. Its a 90 crx hf with an 88 rex body and engine harness. The inside has nothing in it, no gauges nothing. Three wires coming off the sensor, 1 y/wht , 1 y , 1 blk. Black is ground, yellow is ign1 i believe, and yellow with white is the sender wire. I am planning on just hardwiring it all in. Just need to know where i should tap into for the power wire.. ie. the yellow wire.
Thanks in advance. Ryan
