Old 07-23-2018, 05:46 PM
jlc55's Avatar
jlc55 jlc55 is offline
2003 alero a/c problem
Have a 2003 alero 4 cylinder and having trouble with the a/c. One day it was working fine and the next day it stopped working. I have checked all fuses that have to do with the ac compressor and climate control and no luck. Blower is working fine only the compressor is not engaging. Any ideas to what the problem might be would be appreciated. Thanks.
Old 07-25-2018, 12:45 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 2003 alero a/c problem
check for adequate refrigerant pressure (47+ psi)
Then check if clutch pulls in-- tap it if it doesn't- may have the classic "too wide air gap issue"
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 07-25-2018, 07:10 AM
jlc55's Avatar
I double checked it yesterday again...but didn't check pressure. The compressor is not engaging so I disconnected the connector to compressor and connected it direct to battery and it worked. There is no power going to compressor..all fuses and relays are ok. Would the ac control panel have something to do with the problem?
Old 07-26-2018, 12:01 AM
brcidd's Avatar
Loss of refrigerant is number one cause of compressor not engaging-- I highly suggest you see if system has 47+ psi in it.....if not, you have a major leak that needs to be found and fixed. Borrow the pressure gages from Autozone to test.
'99 GMC Yukon
Old 07-26-2018, 07:54 PM
Tech II Tech II is offline
You not only need gages to check what the static pressure is, hi=lo=ambient air temp, first thing in the morning before the car is started....so if the air temp is 70F, pressure should be 70 PSI.....if much lower, you have a refrigerant level problem.
If gage pressure looks ok, then you need a scan tool to read data to the PCM....this system uses a 3 wire pressure sensor(which can't be jumped like the old pressure cycling switch)......the sensor should be giving the SAME PRESSURE INFO AS THE GAGES........if it is giving too low or too high a pressure, the compressor will not run..........
Old 07-27-2018, 07:12 AM
jlc55's Avatar
System had no pressure. I put in small amount of freon and discovered the leak. It's leaking thru the low pressure valve...don't know how I can tighten it...don't wanna break the valve��
