Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 07-22-2018, 01:22 PM
armarm1 armarm1 is offline
Truck stops accelerating
I have a 2003 GMC Envoy. A couple of months ago I noticed I would press my gas pedal and it would be slow to get power. Its gotten worse now. I'll slow down and go to accelerate and the truck just smoothly rolls like its coming to a stop. I'll have to press the gas over and over again and it eventually moves. While I am pressing the gas the RPM is not moving. When the truck finally does jerk into motion thats when the RPM needle moves. There is no code showing. I've even taken it into Autozone and had them try to find a code but they don't show anything as well. This is getting to be very scary cause I feel eventually the truck will just finally come to a stop in the middle of traffic. I won't even get on the expressway anymore. We have statrted with the cheapest fix of changing the gas filter but that hasn't helped. Any suggestions? The truck is 2003 6 cylinder 4.2L engine S
Old 07-22-2018, 09:36 PM
maxwedge maxwedge is offline
A990 racer
Re: Truck stops accelerating
Welcome to AF, this is impossible to diagnose from here, many things can cause what you describe, do you a fuel pressure tester? Do you have reasonable mechanical skills, how old is the fuel filter?
Old 07-23-2018, 12:37 PM
Tech II Tech II is offline
Well, you shouldn't be driving this vehicle......
What I would do is go to a GM shop......set up the paper work so it doesn't have to be done later(nothing can be done or charged until you sign).....
THEN when the car acts up, call the dealership and tell them it is acting up, and see if you can bring it in immediately to be looked at....
The Following 2 Users Say Thank You to Tech II For This Useful Post:
armarm1 (07-25-2018)
Old 07-23-2018, 08:04 PM
Blue Bowtie's Avatar
Registered Offender
This is a throttle-by-wire scheme. There is a potentiometer connected to the accelerator pedal, inside the vehicle. Check the electrical connections, and try a plastic-safe electrical contact cleaner such as CRC QD on the potentiometer to see if it improves. You could also meter the resistance (engine off) as you move the pedal through the range.
It would also be helpful to inspect the electrical connector at the throttle motor, on the throttle body.
Old 07-24-2018, 08:13 AM
Blue, usually the TAC system will set a code for this situation...he said there were none....
Old 07-24-2018, 06:43 PM
Registered Offender
...Unless it is slipping.
Old 07-24-2018, 09:26 PM
Uh, exactly what do you think is slipping?
Old 07-25-2018, 09:46 AM
777stickman 777stickman is offline
How about a good Throttle Body cleaning?
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 07-25-2018, 03:35 PM
Thank you. The fuel filter is brand new. I just had it put in last week 7/18. I'm thinkiong of trying to replace the sensor next.
Old 07-25-2018, 03:37 PM
Thanks. I will try this.
Old 07-25-2018, 03:39 PM
Thank you so much. I will def forward this info on.
Old 07-25-2018, 08:30 PM
Registered Offender
In Envoys /T-Blazers with adjustable pedals, the mechanism can slip past the accelerator sensor lever and not actuate.
Old 07-30-2018, 06:55 AM
r0cdr r0cdr is offline
Sounds like it is going into "limp" mode. Happened to me intermittently for a few days then it flat quit paying attention to the throttle. I took an hour in very annoyed heavy LA traffic (I got off the freeway in time) to go the 5 miles to my shop - I was lucky to be so close. Throttle body assembly had basically fallen apart & the computer could see that the throttle didn't do what it was being told and went into limp mode. replaced throttle body assembly - cant remember what else as this happened several years and a 150000 miles ago. Not too unhappy as the truck had 200K rough miles on it, and its still going at 360K. Early 2002 model bought new. The poor truck really works for its cookies as I do a lot of 4wd mountain dirt roads.
The Following User Says Thank You to r0cdr For This Useful Post:
armarm1 (08-04-2018)
Old 07-30-2018, 12:39 PM
When it goes into limp mode, it will set a code....
Old 07-31-2018, 05:22 AM
Registered Offender
Slipping in a different location then.
Tags
acceleration , envoy , losing , power , slow
