Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 07-17-2018, 12:50 PM
bellajade24 bellajade24 is offline
Unhappy 2004 gmc envoy xl (stalling?) (rough idle)
I have a 2004 GMV Envoy XL. 184K V6
When the car is in park with the hood up watching it. The fan will slow down and the motor will move around. Almost like it is about to die. And then a few seconds later the car sounds like someone hit the gas. And then everything goes back to good. Also when idiling the rpms do move some but not alot. It also has a loud repeated tick sound.
Recently I replaced the water pump but this problem was occuring before that.
Old 07-17-2018, 07:09 PM
maxwedge maxwedge is offline
A990 racer
Re: 2004 gmc envoy xl (stalling?) (rough idle)
Can't tell what the ticking is from here, but get or have the throttle body cleaned, may correct the stalling.
Old 10-18-2018, 10:14 AM
mikehuggins873 mikehuggins873 is offline
does it only idle rough when ac is on or heat if so throttle body needs cleaned if not check codes for 0128 temperature sensor high low temp possible stuck thermostat or sensor is out
