Go Back   Automotive Forums Car Chat > Pontiac > Torrent
Old 07-06-2018, 10:31 PM
tonydiato tonydiato is offline
Send a message via AIM to tonydiato Send a message via Yahoo to tonydiato
Back lights and Instrument panel does not light up
I have a 06 Torrent. My instrument panel does not light up and my back lights do not work. The break lights and back up lights work, but the lights in the back that are to be on when driving at night do not light up along with the instrument panel.
Is this a fuse? I checked the fuse box, but I do not see anything that says lights?
Old 07-07-2018, 09:22 AM
Tech II Tech II is offline
Re: Back lights and Instrument panel does not light up
OK, if you manually turn your headlight switch to Park, the rear park lights do not light? What about the front park lights?
There is a PARK fuse in the I/P fuse block, and it powers the front and rear lamps .....there is also a Park LP relay that is grounded by the BCM.....but if fronts are ok and rears are off, the fuse and relay are ok....
As for your cluster, is the HVAC, radio, transmission shifter indicator, etc., lit up?
If not, check your dimmer switch.....
Old 07-07-2018, 10:56 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Parking lights and instrument panel are on the same circuit. Find the blown fuse and go from there.
Old 07-07-2018, 08:04 PM
Steal, I don't think they are......the instrument panel lights are on the dimmer circuit, the park lights are not....
Old 07-07-2018, 08:19 PM
Stealthee's Avatar
The instrument panel runs through a dimmer, but almost every car I've ever seen the parking lights are on the same circuit as the instrument cluster. It's like that so if the fuse blows you know you don't have parking lights.
Old 07-08-2018, 07:54 AM
brcidd's Avatar
brcidd brcidd is offline
Totally agree with above statements. Cars have been that way forever--my Dad's 1967 Caprice had the instrument lights on the same circuit as the tail lights- this is for SAFETY- it lets you know that you do not have tail lights! Totally agree- fix the tail light circuit and all will be fine. Do not drive at night with out tail lights
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 07-08-2018, 08:51 AM
Not in this day of BCM's.....
Looked up the circuits......both are controlled by the BCM.....but each circuit is powered by a different fuse....
Old 07-08-2018, 09:12 AM
That fixed the problem. It was a fuse on the passenger side of the car.
Thanks.
