Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 07-02-2018, 07:34 AM
rdharley3 rdharley3 is offline
03 tranny fluid leak problem
On my 03 1500 suburban 4x4 the tranny finally gave up at 249k. I had a rebuilt tranny installed and after about 1k miles I'm driving down interstate look ;in my rear view mirror and smoke is rolling out of the rear of the truck I look like a crop duster going down the road. I stop check under the vehicle and tranny fluid is raining down from the bell housing area onto the exhaust I get back in notice my tranny temp is about 20 degrees hotter than normal so I put it in gear and limp to the next exit about 2 mile the tranny shifts normally the only difference is fluid 20 degrees hotter once I get off exit while waiting for tow truck I look under truck with engine running from bellhousing back is covered in tranny fluid but I see no fluid leak anywhere. any ideas on what's going on here?
Old 07-02-2018, 07:47 PM
maxwedge maxwedge is offline
A990 racer
Re: 03 tranny fluid leak problem
Tough here to suggest a source of the leak without an onsite inspection. Cooler lines are one possibility.
Old 07-03-2018, 02:10 AM
brcidd's Avatar
brcidd brcidd is offline
Just about always a cooler line- corroded and broke- same thing happened on my Dually....had to splice in a temporary hose fitting until I could get home and replace the entire lines.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 07-03-2018, 06:45 AM
Blue Bowtie's Avatar
Registered Offender
With a fresh rebuild and hot trans, it could also be the vent line burping oil.
Old 07-03-2018, 11:28 AM
Ok here is what I did yesterday after truck sat all night checked fluid nothing on stick filled fluid back up to full it took 1 quart got underneath truck wiped down all traces of fluid with truck running did not see a leak anywhere put cardboard underneath let truck run for 20 minutes there is a slight leak coming somewhere on passenger side above exhaust crossover pipe I cannot tell where it is coming from as the only drip I see is underneath pipe on passenger side of truck.
Old 07-27-2018, 02:24 PM
j cAT j cAT is offline
if has happened before after a tranny job the fluid lines may leak running to the radiator ....see if they are loose use a line wench ..don't over torque the fitting ..
maybe tough to get at ..on tranny pass side..
