Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-29-2018, 05:06 PM
wmkosm wmkosm is offline
Camry 1999 - Engine Light Code P0340
Please Help,
History when first happen to my camry 1999 5SE V4.
1.Start engine - with engine light appear
2.Switch Off engine & check - try to start but no crank.
3.Check battery - week.
4.Change new battery - enable to start, drove about 1 hour, but engine light ON & OFF
5.Switch Off engine - try to start but no crank.
6.Check repair Starter - enable to start - but engine light still appear
7.Scan engine light - P0340 Camshaft Position Sensor 'A' Circuit Malfunction
8.Change - Camshaft Position Sensor - Scan & Erase still code P0340.
9.Check & Change new Timming Belt - Code P0340
10.Check & Redo wiring - Scan & Erase - Code P0340.
Any Ideas what to do next.
Thanks
Old 06-29-2018, 08:19 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Camry 1999 - Engine Light Code P0340
If you haven't,
1. Trace the wiring for continuity from the CPS to the ECM.
2. Clean both sets of contacts of the CPS with electronics spray.
3. See if you can't temporarily replace the ECM with one that you know works.
Do you have a maintenance manual for your vehicle?
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
The Following User Says Thank You to Brian R. For This Useful Post:
wmkosm (06-29-2018)
Old 06-29-2018, 09:27 PM
I will do what as recommended.
Will update the result.
Old 06-30-2018, 06:14 PM
Brian R.'s Avatar
Resident Chemist
Check the resistance between the terminals of the CPS. (I know it's new)
Cold 835 – 1,400 ohms
Hot 1,060 – 1,645 ohms
If it's bad, buy a DENSO or NGK sensor, only.
Old 07-04-2018, 08:08 AM
Solved
Check the resistance between the terminals of the CPS, found that broken wire. No engine light
Thanks
The Following User Says Thank You to wmkosm For This Useful Post:
Brian R. (07-04-2018)
Old 07-04-2018, 11:26 AM
Brian R.'s Avatar
Resident Chemist
Thank you for reporting the fix.
