Go Back   Automotive Forums Car Chat > Saturn > Vue
Old 06-19-2018, 05:52 PM
rushedusername rushedusername is offline
2003 Vue won't move at all
I have an 03 Vue 2.2l 4 cylinders, it ran great until now. I took the car for a drive, and it had difficulty accelerating. Every time I tried to accelerate, the car would lose power, kind of if the car thought I took my foot off the pedal. I then inspected nothing visibly wrong and all the fluids were fine, when I started the car back on, now the car won't move at all in any gear, all it does is rev. And I have a CVT transmission instead of VTi.
Can someone lend a hand?
Old 06-20-2018, 01:26 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: 2003 Vue won't move at all
"VTi" is just Saturn's name for the CVT that your Vue has. It's all the same. If the vehicle won't move while in gear, the transmission has probably bit the dust. I know you said you inspected the vehicle, but the only other thing that would cause the vehicle to not move is a broken CV halfshaft.
You can install another used/rebuilt CVT, but that's not really a viable long-term solution. The general consensus is that installing another transmission is a much better option. The Aisin AF23 is most commonly used. It's a reliable, 5-speed automatic transmission sourced from a 2003-2004 Saturn Ion Sedan. A manual transmission (Getrag F23) from another Vue could also be used, but requires more work due to the addition of the clutch pedal & shift cables. Installing the manual gear shifter would also be required, whereas the Aisin AF23 is able to use the existing shifter. The This can be done for well under $1000 if you do the work yourself.
The SaturnFans forums are a great resource for this project. I've provided a link here to point you in the right direction.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
The Following 2 Users Say Thank You to Ruley73 For This Useful Post:
rushedusername (07-31-2018)
