Go Back   Automotive Forums Car Chat > Jeep > Liberty
Old 06-17-2018, 05:35 PM
rhandwor rhandwor is offline
Fan control problems.
What sends the signal to the high speed radiator fan circuit. I think the ECU completes the ground for the high speed relay.
My other vehicles had two fans and the ac was turned on the other fan run. This vehicle has a two speed fan. Does the coolant temperature sensor tell the ECU when the temperature is high and completes the ground for the high speed relay.
Old 06-19-2018, 05:44 PM
Re: Fan control problems.
I hooked up my scanner and put it on data stream and monitored the operating temperature. A new Gates thermostat fixed the problem.
I used a logic probe and the high speed relay was getting proper signal, This vehicle will set a code when unplugged.
