Old 06-12-2018, 11:02 PM
Schurkey Schurkey is offline
Pulse / Delay / Intermittent Windshield Wipers
I'm borrowing a friends '89 K1500 extended cab while my '88 is down with a popped engine. Part of my "rent" is that I get to fix about a thousand things that are broken or non-functional on this vehicle.
Today's successful project was to get the windshield wipers functioning reliably. The wipers haven't been reliable for months. This became a priority as yesterday it POURED ALL FRIGGIN' DAY and Rain-X wasn't handling it.
The wipers would work...sometimes. They might work for several miles then quit, they might not work for miles--or days--then start up again. There was no pattern, and twisting/pulling/wiggling the Multi-Function Stalk did nothing productive. When I started work on this thing, the wipers were totally dead--no pulse, no low speed, no high speed.
I disconnected the 5-wire molded plug from the motor under the hood, and stuffed a test light into each of the five connections in the molded wire harness end that plugs into the wiper motor. I had some power, I had some ground. I plugged the connector back in, and pushed 'n' pulled on it a little. The wipers would work as long as I applied pressure. I took a wild guess, and bought a wiper circuit board. About $30.
In one place, it says "Remanufactured". In another, it says "New". I think the thing is new, not reman--But I don't know for sure. I really hate "Made In China". But what am I gonna do?
Well, I pulled the three Torx-head screws that hold the cover on. They also hold the circuit board "in". The board pulls right out other than some friction from the three connections at the lower left in the photo below.
The grease inside was hard. I added some fresh onto the worm gear at the very bottom. The grease you see in this photo is original.
On a whim, I grabbed a magnifying glass, and looked at the solder joints on the original circuit board. The first ones I looked at were the six solder joints nearest the harness connector. (lower, right side in photo below.)
There's one that is covered in Conformall, a moisture/weather barrier--the red blob near the "Pulse" molded-plastic harness connector. It's the same red crap on the left side of the board. I could see--with the magnifying glass--that the solder joints were broken on three of the six connections close to the harness connector, next to the red blob.
Three minutes with a soldering iron, some rosin flux, and two inches of thin-gauge solder. Six joints re-flowed. I did a quick inspection of the other joints that didn't have the red Conformall on them and they seemed OK. I left 'em alone.
There are two "arms" that make contact with the big, round disc in the motor housing. They're on the back-side of the circuit board, and I don't have a photo of them. One was covered in hardened grease. I cleaned 'em both, and I bent them "up" for more pressure on the disc.
I slapped it back into place, put the screws into the cover and tightened. Snapped the wire harness into place.
POW! Wipers work just like they should. Every time. Pulse, low-speed, high-speed.
Fixed.
All that's left is to return the Chinese circuit board to NAPA for a refund.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 06-13-2018, 06:02 AM
Blue Bowtie's Avatar
Registered Offender
Re: Pulse / Delay / Intermittent Windshield Wipers
Pretty common. I've had to do that on both my half-trucks and one Astro. Good documentation!
Old 06-14-2018, 04:54 AM
brcidd's Avatar
brcidd brcidd is offline
Very very common- I've been doing this fix for 20+ years.....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
