Old 05-16-2018, 10:27 PM
hondadad2622 hondadad2622 is offline
1999 Escort SE-Basically no air through vents
Changed blower motor and resister thinking I had bad one of the two. Cleaned intake above blower motor attached. I had a couple of leaves. New fan works great just not through vents. The fan speeds work. The switch from ac to just fan, defrost, floor etc. does move. I can hear the "valves, switches" moving on command. There is just a faint flow of air at the different locations as I move the switch. The compressor is switching on as I move the switch to ac.
I have read posts here first as always. I know vacuum sounds like the next level but are there any other mechanical switches, relays, that could be causing the issue?
RECAP:
Fan switches to all speeds fine!
Fan resister new
Fan switch fine in all levels
Main Switch(vent,defrost,floor,ac,max ac) works great - I can see vacuum switch move as knob is turned.
Fuses All good
Air barely flows from vents when fan is on high! Verified fan working
What am I missing?
Thanks in advance for all the help!
Joe
Thanks from a dumb old dad! Like a bunny with that battery, I have to keep going and going and going on this car!
