Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 05-04-2018, 08:54 PM
xcalibersharp xcalibersharp is offline
Angry 2005 Aveo Valve Cover Gasket
Had some oil leakage coming from the valve cover. Got a new gasket put it in only to have a small leak the next day. Opened it up to reseat the gasket and it was in pieces. Anyone have any idea how or why the rubber would split into several pieces. It went in with little to no effort.
Old 05-04-2018, 11:11 PM
aleekat aleekat is offline
Re: 2005 Aveo Valve Cover Gasket
What brand?
Post back, that's what makes Forums Work.
Old 05-05-2018, 01:52 PM
Fel-Pro
Old 05-08-2018, 10:11 AM
rhandwor rhandwor is offline
You can't tighten valve cover gaskets to tight. The same way with hose clamps.
Compress the rubber some but not to much.
Old 05-08-2018, 01:15 PM
Tech II Tech II is offline
There is a specific torque spec in INCH-POUNDS, for the bolts for the valve cover.......I have sometimes coated the top and bottom of the gasket with RTV before installing......put it together right away, don't want the RTV to "skin".....
