Old 04-29-2018, 05:26 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
larger tire size
'99 silverado.
Currently sitting on 245/75/16s. Is this the stock size?
I want something bigger without a lot of hassle. I've been searching the forums but haven't seen a unanimous answer yet. I saw where someone was able to do 285 75 16 by raising the torsion bars 1 inch, but that was in c/k forum so I thought it would probably be different. Also should note that they said they have slight rubbing in the rear at full wheel turn.
My silverado is 4x4, extended cab and stock afaik
been looking at http://www.tire-size-calculator.info/ but it doesn't tell me if a larger size will rub. I'm a bit curious about the difference in speedometer (noted there) and how it'd affect the odometer
This ain't your grandma's car!!
Old 04-29-2018, 09:27 PM
777stickman 777stickman is offline
Re: larger tire size
I ran 265's on my '99 Sub K2500, but I had custom rims that would accommodate the larger tires. Will your rims do that? Your owners manual or a google search will tell you what came stock on your truck.
Larger tires will effect the speedo as it will show slower than actual. The odo is also effected. An example would be 100 actual miles would show on the odo as 80 miles. Fuel economy and towing would also be effected as bigger tires equal higher gear ratios and added stress on the drive train.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 04-29-2018, 09:38 PM
gw84's Avatar
well dang, maybe I don't want to do that then. Perhaps I should stick with a slight lift. Tired of the stock look.
Old 04-30-2018, 07:21 AM
CapriRacer CapriRacer is offline
If I have this right, a stock 1999 Silverado 4X4 with P245/75R16's had 6.5" wheels - and that means you can't go up in size without encountering other problems. Using a wheel that is too narrow tends to make the tire tread arch, and the vehicle would tend to follow the ruts in the pavement and be sensitive to cross winds.
Old 04-30-2018, 09:40 AM
j cAT j cAT is offline
you have stock tires 245. 265 no problem ...
above this size can be problem and also program changes for speedo.
you want to go higher use 18inch wheels .16inch not good on your change idea.
