Old 04-17-2018, 10:09 AM
wjamaica4 wjamaica4 is offline
Help, EGR tube broken
I have a 1998 Windstar, one of the small tubes on my egr pipe finally broke off. It was lose for some time. However, it is a discontinued part. All of my sources are exhausted for a replacement part. Just wondering, I do have the pice that broke off, is it possible to weld or braze it back into place?
Old 04-17-2018, 04:49 PM
tomj76 tomj76 is offline
Re: Help, EGR tube broken
Brazing or welding is possible with steel. Brazing is much like soldering but at a much higher temperature. Brazing works best when capillary action can draw the molten metal into the joint (like in soldering). The best choice of filler metal is silver, but it works best when tight fitting joints are brazed. The big advantage of brazing is that it doesn't melt the metals that are joined, only the filler.
Welding is obviously an option, but I think this would be a difficult weld to make, since you run the risk of melting the small tube. Also the final joint may have holes.
Another option might be a high temperature epoxy, particularly if you can reinforce the joint with a second larger or smaller pipe. The reinforcing pipe should have an inner diameter that matches the outer diameter of the EGR tube, or outer diameter that matches the inner diameter of the EGR tube. Once epoxied (or brazed), the reinforcing pipe will give extra strength to the joint.
Old 04-17-2018, 05:23 PM
12Ounce 12Ounce is offline
Is yours a 3.0? Summit claims to have a Dorman # 598-111 that may work for you ... at under $50.
Old 04-22-2018, 10:00 PM
I like the idea of the tube within a tube. My engine is a 3.8
Tags
aluminum , egr , replace , tube , weld
