Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 04-12-2018, 09:33 AM
Copytech99 Copytech99 is offline
2001 Montana Brake Lights Question
Recently helped out on a failed brake bulb and have question......
Are there 2 brake lights per side ? 1 at top and, 1 at the bottom total of 4 ? (Minus the center high mounted)
It appears that there ARE 2 brake bulbs per side to me.
Thank You.
Old 04-12-2018, 11:42 AM
Tech II Tech II is offline
Re: 2001 Montana Brake Lights Question
OK, so what happens when you step on the brakes? How many light up?
My schematic shows one per side....
How many bulbs are in one rear lamp module? Think you should have one single element bulb for reverse, one single element bulb for tail lights, and one double element bulb for tail and brakes......not sure if a side marker(parking light) is used in the module....
The Following User Says Thank You to Tech II For This Useful Post:
Copytech99 (04-12-2018)
Old 04-12-2018, 01:29 PM
When brake is applied only the top lights. But, I could swear that lowest bulb looks like a dual filament. The only thing I can think is they did not have a single filament bulb that would perfectly match the tails brightness/lumens of the 3057 dual filament used for brake/tail.
Might just be over thinking this.
Thanks for quick reply !!!
Old 04-12-2018, 03:06 PM
aleekat aleekat is offline
Section 6-39
https://my.gm.com/content/dam/gmowne...ana_owners.pdf
Post back, that's what makes Forums Work.
The Following 2 Users Say Thank You to aleekat For This Useful Post:
Copytech99 (04-13-2018), Tech II (04-12-2018)
Old 04-12-2018, 08:03 PM
Good find Aleekat.....
Old 04-13-2018, 08:02 AM
Looks like 1 brake light per side.....
Thanks to all !!!
