Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 04-11-2018, 02:30 PM
DrRadar DrRadar is offline
Just a guy
03 Explorer XLT: Driveline fluid changes
140k on 03 XLT and I'm ready to change driveline fluids.
Transfer case: It appears 1.5qt of Mercon. I've seen cautions against using Mercon V...to be sure the fluid is safe for transfer case. Still true?
Rear differential: 3.55 non-limited slip 8.8" (code 45): The manual says fluid is for "life" and doesn't need to be changed, but I'm skeptical. Proper fluid is synthetic 75W140 with "friction modifier" - correct? How much friction modifier?
Front differential: 80W90 - right? No friction modifier - right? Does it have to be synthetic? (I already have conventional 80W90 in garage.)
Lloyd
18 Charger ScatPack 392
18 Lincoln Navigator L (Hers)
98 Grand Prix GTP Sedan (RIP)
99 Grand Prix GTP Coupe (to the moon)
05 Wrangler Unlimited (Junior's)
03 Explorer XLT (Sissy's)
Old 04-12-2018, 04:53 PM
65comet's Avatar
65comet 65comet is offline
Re: 03 Explorer XLT: Driveline fluid changes
The Mercon V is synthetic version of Mercon, great for transmissions built with the proper seals, but bad for everything else.
I can't comment on synthetic gear oil, I've always used standard. I know some racers swear by the synthetic, but they aren't going 100,000 miles or more between changes.
The Following User Says Thank You to 65comet For This Useful Post:
DrRadar (04-13-2018)
