Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-30-2018, 12:59 AM
AJ&J AJ&J is offline
Stalls - No crank, intermittent. 95 k1500
My daughter drives this vehicle. It died on her and she could not get it to crank. We had replaced the battery a couple of weeks ago, so I had her check the cables, still no crank. I had her put it in neutral and try to crank, nothing. About 20 minutes later, it started just to die again within 5 minutes.
Any ideas on where to start looking? If it was just the no crank I would look at the starter, but the stalling??
I searched the forums before posting this,
Thank you,
AJ
Old 01-30-2018, 10:33 AM
maxwedge maxwedge is offline
A990 racer
Re: Stalls - No crank, intermittent. 95 k1500
Check the ground side cable to the chassis or block, look closely for corrosion.
Old 01-30-2018, 07:21 PM
777stickman 777stickman is offline
Try this. Turn the headlights on and then try to crank. If the headlights go out when you go to crank you have bad cables or connections.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
