Old 01-24-2018, 03:31 PM
glc4123 glc4123 is offline
2002 chevy cavalier
yes, i own a 2002 chevy cavalier and when i start up the engine will miss for approx 30 seconds and then runs smooth only when it is cold. does anyone what the problem is and where to start at.
thanks
Old 01-25-2018, 12:58 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 2002 chevy cavalier
SES light on? If so read codes- could be as easy as a fouled spark plug. Or you can run some injector cleaner in your next tank of fuel- I've had that fix my issue.....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 01-25-2018, 08:22 PM
Tech II Tech II is offline
Are you losing coolant or is the engine overheating?
It could be coolant in the cylinder(s), from a failed head gasket, burning off on a cold start....
The Following User Says Thank You to Tech II For This Useful Post:
glc4123 (01-27-2018)
Old 01-27-2018, 03:50 PM
is there a test to see if it is a leak head gasket? thanks for the help
Old 01-27-2018, 08:31 PM
First on a cold engine, top off coolant if needed...
Next run vehicle to normal operating temp.......shut off......safely remove radiator cap(if no rad cap, remove the reservoir pressure cap)......you will need a pressure tester, with a special adapter to attach to the reservoir, if there is no radiator cap......pressurize system system overnight.....testers can be borrowed from places like AutoZone.....
Next day, remove spark plugs, disable fuel and ignition(remove fuses or disconnect harnesses)......have someone crank over vehicle and watch spark plug holes....if coolant comes out, you found your problem....
