2000 Toyota Camry Issues - stalls when warmed up
I have a
2000 Toyota Camry 4cyl and replaced the following: Cam Shaft Sensor MAP Sensor TPS Spark Plugs Timing belt (I do suspect this maybe is off because the issues STARTED after someone replaced this) Front Break pads Radiator Vehicle Speed Sensor PCV Valve EGR Vacuum Modulator Crankshaft Sensor Clean EGR Fuel Pump The pump was replaced and I had to rewire this) Fuel Filter I plan on replacing the KNOCK SENSOR when that part gets here.... And I am still getting P0171 P0300 P0301 P0302 P0304 P1780 (Park Neutral switch) codes The car starts after 2-3 turns of the key but when the car warms up, the misfire begins and STALLS OUT within 5-10 miles. The car will start 30 minutes later. When it was very cold, the car ran FLAWLESSLY so that means that when something gets hot..... it stalls the car. What the heck is wrong here? |
Re: 2000 Toyota Camry Issues - stalls when warmed up
Vacuum leak somewhere. Warms up, metal expands, leak starts. Try carb cleaner test.
I made sure I sprayed around the intake to see if there was a intake gasket leak and no change what so ever. |
