Old 01-20-2018, 04:10 PM
502_belden 502_belden is offline
2012 traction control / Stabilitrack
Hello, I have a 2012 Chevy Silverado 1500 LT extended cab with the 5.3L V8 motor, 6 speed Automatic Transmission, and 4 wheel drive.
I have a Traction control / Stabilitrack light that has came on and will not go off. When I try to read a code from the truck it does not show a code with my handheld code reader. Is there a reasonably priced code reader that can read the transmission codes ( Do not think mine is capable of Transmission codes).
Back to issue: There is a single switch in my truck that is designed to turn on or off this function (currently not causing any change of condition). Light came on about 35,ooo miles for a single day and went back off. The light has t has recently came back on, and the truck now has 115,ooo miles on it. I have serviced the truck since new by the manufacturer specifications. (Currently the 4 wheel drive is functioning properly and the truck other wise drives properly... engages and disengages).
Truck has recently had front struts and rear shocks replaced. The light was on prior to replacement of these parts. Any assistance I can get with this issue will be appreciated.
Thanks!
Old 01-20-2018, 07:58 PM
maxwedge maxwedge is online now
A990 racer
Re: 2012 traction control / Stabilitrack
Welcome to AF, you need to use a scanner that can read abs codes and data, check online for whats available.
Old 01-26-2018, 10:57 AM
Thanks, I purchased a Scanner it was showing 6 codes. Co710 steering position sensor, Co253 Left rear wheel speed sensor. CKT open or short or centering error.
Those two are self explanatory... chek connection, if it is good replace sensor.
The codes that are more interesting are
v0100 lost communication with ECM/PCM
V0101 lost communication with Transmission Control Module (TCM)
v0102 ....stated... refer to the vehicle service manual
v0140 ...stated ... refer to vehicle service manual
i cleared the codes and everything has stayed away so far except the first two codes pertaining to the sensors.
i would appreciate any information regarding the last 4 codes...
Thanks in advance for your assistance.
