Old 01-17-2018, 04:11 PM
geneo1996 geneo1996 is offline
1996 Grand Am ignition key problem
My grandson's 1996 Grand Am ignition key can be removed in any of the switch stops. This has lead to drained batteries as someone not aware moves the car and pulls the key on the first on position before Lock, GM wants $788 to replace switch? I suspect that I just need to replace cylinder, or if I need to replace a $50 switch, is it that complicated that GM charges almost $800?
Old 01-17-2018, 07:55 PM
Tech II Tech II is offline
Re: 1996 Grand Am ignition key problem
The key goes into the lock cylinder, the lock cylinder slides into the PassLock Module and the module/cylinder, as a unit slides into the ignition switch.....the ignition switch has nothing to do with retaining the key......
The problem is either the lock cylinder or PassLock module.....it would have to be removed and it's operation checked.......There is a special procedure for removing this.......a manual or online subscription would show this...
Basically, you turn the key to the "on" position and you depress a tab, and the key/cylinder/module slide right out....there are several ways of getting to this tab.......manual shows this.....
Old 01-17-2018, 11:07 PM
Thanks for insight
