Go Back   Automotive Forums Car Chat > BMW > Technical
Old 01-17-2018, 03:29 PM
venziar venziar is offline
Please Help
HI All
I am in the plan of buying a used car.
I had a dealer selling me BMW 2005 745 LI - 108840 Miles - 7000$
They did an Inspection and the Report says.
Report Says:-
68 Point Inspection w/5 Miles Test Drive - Includes Oils & Filter
Change(1.3)
Engine Size
Oil Filter
Vehicle Oil Type
Technician
Vehicle Inspection Report: -
Needs:- Wipers (.2), Air Filter (.3), Further Diag on Passenger Wiper INOP (Movement & Spray), Power washing and checked for leaks (.5), Right Rear Window Switch (.5), Value Cover Gasket Leak Class 2-3 (6.1),Rear Main Seal leak Class 2-3 (9.3), Tranny Cooler Lines Leak Class 2 (1.9), AC high Pressure Line leak Class 2 (1.6), AC compressor leak Class 2-3(2.6), Power Steering Pump Leak Class 2-3 (2.4), Power Steering Res leak Class 3 (.8)
Recommending: Front Crank Seal Leak Class 2-3 (3.1), Rack & Pinon Leak Class 2-3 (9.8), Oil Pan Gasket Lower Leak Class 2 (1.8), Coolant Flush - Res Full of H20 (1.3), Noised while Braking
Brakes @10MM, Rears @8MM
Tiers @ 9/32Fronts, 7/32 Rears with Even Wear 2455018
No Codes, No Modification Noted
Is this a worth buy ?
What are all the problems I might get with all this mileage and with all this issue ?
Car Fax is good I don't know anything about car I am buying car for the first time.
Please help earliest sir..
Thanks in Advance.
Tags
2005 , 745li , bmw , mechanical
