Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 01-15-2018, 08:13 AM
clutch492 clutch492 is offline
ASE Master Tech
3.0L flooding and won't start. SOLVED
Recently, I have been struggling with this 2004 Dodge Stratus Coupe, R/T, with the 3.0L Mitsubishi V-6. Flooding and will not start. Timing belt was on the mark, crankshaft position sensor was showing RPM on the scanner, it was showing spark on the spark plugs, and had great compression and flooded cylinders. It was difficult. HOWEVER, the spark was a WHITE color. It ended up being a WEAK COIL. It is located in the distributor. I replaced the entire distributor with one from AM Autoparts off of eBay. Started right up and runs great. I want everyone to know that just because it had spark, doesn't mean that it was good spark. The COIL WAS BAD. Nobody would post the answer to this problem. I started this new thread to clear that up. Thanks to everyone who pointed me in the right direction. This includes my fiancé Carmella. She stated that the spark was WHITE, not HOT (orange or blue). Thanks to all of you.
