Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-14-2018, 12:58 PM
chuck's chuck's is offline
95 Dodge rear wheel anti lock valve
I am seeking to replace the anti lock valve assembly on my truck. I did not realize that trying to find this part would be so difficult. I am going to guess that this Kelsey Hayes valve should be easy to find since Ford, GM, Dodge and other manufactures used the same rear wheel anti lock system. If anyone has info as to where to get this item, please let me know. Thanks.
chuck's
Old 01-16-2018, 04:43 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 95 Dodge rear wheel anti lock valve
Like this?
https://www.moparpartsoverstock.com/...category=22688
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 02-10-2018, 02:56 PM
I have been able to replace the rear ABS valve. I started with purchasing a rear ABS valve for a 1994 Chevy 4x4, 2500. I had to make some changes since the port sizes are different for the Chev. I had to shorten a transition brake line, rewire the solenoid wiring, found a male metripak 280 four prong shell, male pins and wired it as per Dodge wiring. Amazingly I am now hearing the solenoids get activated during the key ON, ABS self test.
The Following User Says Thank You to chuck's For This Useful Post:
Chris Stewart (02-11-2018)
Old 02-11-2018, 07:45 PM
AF - Advisor
Thumbs up Re: 95 Dodge rear wheel anti lock valve
That is fantastic and some mighty fine ingenuity, congrats on a job well done
Old 02-11-2018, 11:56 PM
I also learned today that a daytime running module from a 1995 Jeep Cherokee is the same for my Dodge. I have never seen a listing for an aftermarket daytime running lamp module for my Dodge. I have always had to go to the dealer and pay lots $$$$. Now that I know this, it will be aftermarket modules from now on. Info that could get passed to other Dodge owners. Thanks.
chuck's
Old 02-12-2018, 08:59 PM
AF - Advisor
Good, thanks for the info.
Old 09-02-2018, 07:25 PM
My factory DRL module failed and ordered one for a 1995 Jeep. Plugged it in and it all works for half the cost. I am hoping it will last longer than the factory one.
Chuck's
Chris Stewart (09-02-2018)
Old 09-02-2018, 07:38 PM
AF - Advisor
That's an interesting parts interchange, thanks for the info!
