Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-06-2018, 12:07 AM
lemonmint lemonmint is offline
2015 Camry SE Rust issues
I bought a used car recently with 20K miles on it and took it to Toyota service center for pre-purchase inspection and came to know of rust issues. The car has been in Ohio (cold/snow/salt exposure) for the past few years with no issues mentioned. The following are the issues mentioned:
1. Break rotors corrosion at the edges
2. Rusting on Muffler/Pipe assembly
3. Front CV axle corrosion
I will be driving the vehicle in Texas mostly around Austin area which is neither cold nor humid. I have an option to return the vehicle with little hassles but I really like the car (no other issues at all) and would keep the vehicle if any remedial/preventive measures would help me. Can anyone help me with questions like:
1. Is this common in North America (salt belt - https://en.wikipedia.org/wiki/Salt_Belt)? If so, what measures do they take to avoid this issue or to prevent it from spreading?
2. How to know if the rusting is surface rusting and can it be avoided/repaired with minimal cost?
3. Is this something to be seriously taken and return the vehicle at any cost?
4. Would manufacturer's warranty cover such a thing?
Any or all the suggestions and help is appreciated.
Old 01-06-2018, 08:09 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2015 Camry SE Rust issues
I don't see anything in those images that would be considered abnormal or something to be concerned with. Spending any time driving on rain-soaked roads would likely cause the degree of surface rust shown in those images. I'm surprised the person doing the inspection even mentioned any of those items as they are very minimal and no "repair" or removal of that surface rust should be required or expected.
-Rod
The Following User Says Thank You to shorod For This Useful Post:
lemonmint (01-06-2018)
Old 01-06-2018, 09:38 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
None of those issues are structural. They also are easily "repairable". The rust on the edge of rotors happens on every car that sees road use. Everything else is normal surface rust.
The Following User Says Thank You to Stealthee For This Useful Post:
Old 01-06-2018, 02:25 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
I would have to agree. These items look normal to me. These are items without plating and will get surface rust like this very quickly in northern states. Nothing to worry about.
Mike
The Following 2 Users Say Thank You to Mike Gerber For This Useful Post:
Tags
camry , rusting , toyota
