Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 01-03-2018, 04:56 AM
bikernut's Avatar
bikernut bikernut is offline
check engine light
on my daughters 2001 GMC Yukon XL with 5.3 engine she went in for the annual state inspection and just before getting there the check engine light started glowing. of course it failed the inspection and they gave here a temporary one for 2 extra months. well being a single mother shen couldn't afford to do this right away so after 4 months she finally could afford it and had it done. now the question is she was told she had to put 100 miles on it to cancel out the code as just clearing it wouldn't work. if she drives in now with an expired inspection ticket she get fined for driving an uninspected vehicle. now is there a way to get the code canceled out with out driving it for 100 miles and risking a ticket. thanks
3500 Dually Member # 252 and Damn proud of it
2016 GMC Denali Dually Duramax w/Automatic
6X6 (rear tires are dual) ..
enough power to pull the old guy
from the P !!ss Pot
2007 KZ New Vision 41kgx2 Toy Hauler
2 Harleys (2015 FLHTCUTG and 1995 FLTCU)
1987 Trans Am GTA (with only 19,783 mile)
1992 Chevy S-10 4 dr, 4x4 Blazer
03 GMC 3500 Dually
Old 01-03-2018, 12:58 PM
maxwedge maxwedge is offline
A990 racer
Re: check engine light
Same issue here in Nys, if you clear the code with a scanner, you must go thru a somewhat lengthy drive cycle so all the monitors come back online. What was the code? Most codes, if fixed, can go thru 10 ignition cycles, still need the code for more accurate advice.
