Go Back   Automotive Forums Car Chat > Buick > LaCrosse/Allure
Old 12-31-2017, 07:04 AM
Bdd8591 Bdd8591 is offline
click no start 2011 lacrosse
new battery and starter but just clicks. any help would be great. checked all fuses and tried both fobs.
Old 12-31-2017, 10:45 AM
maxwedge maxwedge is offline
A990 racer
Re: click no start 2011 lacrosse
So the starter solenoid clicks? Or you just hear an unidentified click noise? Do your lites dim when this happens?
Old 12-31-2017, 11:26 AM
Tech II Tech II is offline
Well, the click is either the starter solenoid, or the starter enable relay in the under hood fuse block.....
Was this the reason for the new battery and starter? Or have they been installed for awhile and this has just happened?
If you can feel/hear the starter enable relay click, when someone turns the key to the crank position, and it doesn't crank, see if there is another relay in the fuse block with the same number and swap relays....if it now cranks over, bad relay....
If it still does not crank over, attach a test light to ground.......now touch the red cable where it attaches to the starter....test light should be bright, just like if you touched the positive terminal on the battery with it......if it isn't we have a positive battery cable problem......now go to the yellow wire connection at the starter solenoid....attach your test light....should be off......have someone turn the key to the crank position.....the starter enable relay should click and you should have the same brightness as when attached to the red wire......if yes, bad starter solenoid.......
If no, there is a 30A fuse(F12UA) that feeds the solenoid...see if the fuse is blown, or check with test light that it is getting power......
Old 01-05-2018, 01:11 PM
Rasp Rasp is offline
I would take a look at your battery wires. They often become corroded. Might be that simple.
Old 01-05-2018, 08:49 PM
Rasp, he said he replaced the battery, so the cables should have been checked then....
Old 01-09-2018, 09:27 PM
sometimes people buy battery's without checking for cable corrosion. Car won't start or turn over must be battery? Easier than actually getting hands dirty and checking a little further.
