Go Back   Automotive Forums Car Chat > Ford > Tempo | Topaz
Old 12-29-2017, 05:14 PM
Slimpickens75 Slimpickens75 is offline
1994 ford tempo
Ì recently purchased a 94 tempo and while doing so I ran into a problem I had a friend start the car while I'll was looking at the motor... so the motor is turning over but yet the serpentine belt is not moving...stop trying to turn the motor over and I grabbed the belt and I could easily move the belt with ease...any solutions would greatly be appreciated before I start replacing parts... Thank you
Old 12-29-2017, 06:20 PM
aleekat aleekat is offline
Re: 1994 ford tempo
What motor?
Did the car run or did you buy it with this problem?
Post back, that's what makes Forums Work.
Old 12-29-2017, 09:09 PM
65comet's Avatar
65comet 65comet is offline
Re: 1994 ford tempo
Well, there is always the chance that the belt resting there isn't the correct one for the engine. But more likely the belt tensioner was moved over into the untension position and locked there. Either because the spring is broken or there is some kind of debris that locked it in that position.
Old 12-30-2017, 09:42 AM
mikerossi mikerossi is offline
Re: 1994 ford tempo
The rubber in the crankshaft pulley (harmonic balancer) separated from the metal ring that the belt rides on. Try to move the pulley by hand in all directions to see if it is still connected.
I had to replace the pulley many times on my 94. I suggest an oem pulley not aftermarket. The aftermarkets sometimes only lasted a few months.
Old 12-30-2017, 09:44 PM
Re: 1994 ford tempo
The previous owners say they started it a few weeks prior to me buying it and claim it was running... they also said they had been driving it and all of the sudden the power steering went out on um... so I'll go Check the options u all gave me and see what the outcome is... thanks for the advice so far!
Old 12-31-2017, 09:08 AM
Re: 1994 ford tempo
Well the power steering went out once the belt stopped turning. Hope they didn't drive it to long since the waterpump would have stopped also and may have over heated the engine.
Old 01-07-2018, 04:25 AM
Re: 1994 ford tempo
So I went back to my car and really did get a chance to check it out other then I believe the pully tensioner is fine cause it had pretty good tension on the belt...so what are my options?
Old 01-07-2018, 09:28 AM
Re: 1994 ford tempo
That's where I would look...
