Go Back   Automotive Forums Car Chat > Buick > LaCrosse/Allure
Old 12-16-2017, 11:42 AM
Making Junk Fly Making Junk Fly is offline
Torque converter.
2005 La Crosse. Do these cars have a lock up torque converter? Can it be disabled?
Old 12-16-2017, 01:30 PM
maxwedge maxwedge is offline
A990 racer
Re: Torque converter.
Yes they do. What is the problem?
Old 12-17-2017, 09:09 PM
At low speed and low throttle it seems that the torque converter is locking up and then unlocking. is there a switch on the brake pedal like was first used that you needed to apply the brake to shift. I just had the transmission flushed and it is working better ,but not this hard lock unlock. Is there any vacuum from the intake to the trans control? Thanks
Old 12-18-2017, 07:50 AM
A990 racer
No vacuum, all electronic controls from the pcm. To avoid unnecessary repairs you should have it scanned with the proper bi-directional scanner to see pcm commands and tcc functions.
Old 12-18-2017, 04:06 PM
harleyguy harleyguy is offline
Before you just go disconnecting the tcc you should really be sure that's the problem. Converter lockup shouldn't be that noticeable of a difference and you will have more problems if you bypass it. Can you describe your problem in a little more depth?
Old 12-18-2017, 08:12 PM
Tech II Tech II is offline
Are we talking about the TCC engaging/disengaging, or about harsh shifts?
Have you scanned for transmission codes?
Old 12-18-2017, 08:20 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
This is exactly what I am thinking.
