Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 12-03-2017, 02:20 PM
bobbyjoes bobbyjoes is offline
Clunking noise
,I just got a 2011 impala 2 months ago ,I put less then 500 miles on it ,when I'm in car and take a sharp left I have loud clunking noise and almost feels like slight hesitation,I too kk home and in driveway turn it all the way left and went back and forth just a bit and a loud clunking noise ,thoughts or need more info let me know,thanks
Old 12-03-2017, 04:50 PM
Johnny R Johnny R is offline
Re: Clunking noise
Sure sounds like a broken coil spring.
Johnny R.
2011 Malibu LT - It's a beaut. So was my '99!
2006 GoldWing 1800 cc - the way to go, coast to coast!
Old 12-03-2017, 06:01 PM
Re: Clunking noise
Well thank s for reply,I hope that's all it is,How could you tell visually or some other way,thanks
Old 12-04-2017, 06:54 AM
Blue Bowtie's Avatar
Registered Offender
Re: Clunking noise
Or a sticking upper strut mount.
Old 12-04-2017, 12:50 PM
Tech II Tech II is offline
Re: Clunking noise
Or the dreaded intermediate shaft clunk.....
Old 12-04-2017, 01:22 PM
Re: Clunking noise
It sounds like when a knuckle is out on 4 wheel drive when you turn it's a lot of clunking growling noise
Old 12-04-2017, 06:41 PM
Registered Offender
Re: Clunking noise
But... But... I thought they had resolved that before 2011, no?
Old 12-04-2017, 07:11 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Clunking noise
Don't know for sure, but my 07 Grand Prix got the ISS clunk. We should all be used to this by now. It takes GM about 15 years before they fix an issue.
Old 12-05-2017, 10:36 AM
Re: Clunking noise
It was bad wheel bearing,should be fixed today under warranty,thanks guys
Old 12-06-2017, 11:06 AM
Re: Clunking noise
Bad wheel bearings don't usually make a clunking noise, the make a roaring/growling noise as speed builds up....but I suppose anything is possible...
Old 12-06-2017, 06:10 PM
Re: Clunking noise
Ok they replaced left wheel bearing,they didn't fix it,when I make a hard left turn or put a load on that side it's a he'll of a sound then it hesitates the car so bad you fly ahead in the seat ,all good on right turn ,crazy
Old 12-06-2017, 07:40 PM
Registered Offender
Re: Clunking noise
Check those struts and mounts yet?
Old 12-07-2017, 09:23 PM
Re: Clunking noise
Have someone sit in the car and turn the wheel back and forth, and you get down by the wheel and have a look/listen. But don't stick your head in the wheel well.
Johnny R.
Old 12-08-2017, 12:09 PM
Re: Clunking noise
Methinks you better find another garage.....
Old 12-09-2017, 09:14 AM
Re: Clunking noise
Ok,i raised it in the air everything seemed tight ,there was a cluck coming from right side ,the the driver side cv. joint with pry bar could not move or no play ,the right side had or passenger side had about a 1/4 to 3/8 inch play
