Old 12-03-2017, 02:39 AM
TravisJGruber TravisJGruber is offline
Transmission downshifts at random
I've already posted it elsewhere on this forum and got a little feedback that was helpful. But my transmission will randomely downshift from 3rd to 2nd. It's a 350 with a shift kit and it worked perfectly fine about a month ago (Shift kit was put in ages ago by the guy we bought it from) We cleaned the modulator and put a new transmission filter in and replaced the fluid but it still downshifts randomely and then refuses to upshift until I manually downshift into 2nd.(Should probably have mentioned this is a '76 camaro with automatic trans.) I am going to spend my afternoon today getting the govenor out because I was told it could be dirty or going bad. It also only downshifts when the engine is warm (Usually about 40 minutes of driving, sometimes less) Please help as I am new to the rebuilding a car scene and want to get this thing running flawlessy before winter sets in.
Old 12-04-2017, 12:43 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Transmission downshifts at random
First thing ... you 'cleaned' the modulator ... what does this mean? A lot of modulators have a screw inside of the vacuum nipple that you can adjust to either firm up or soften the shift, it will also affect shift points. There is also the detent cable which attaches to the throttle on the carburetor - is this properly adjusted?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
