Old 12-02-2017, 08:37 AM
frafreg frafreg is offline
1990 Escort EEC-IV 1.9 L CFI - Cold Start Problem
It runs fine once it is started and starts right away if it is warm but is very hard to start when cold. If I put my foot on the gas slightly, it will start and run fine otherwise. There are no error codes and no other obvious problems. Any help troubleshooting would be much appreciated. Thank you.
Old 12-22-2017, 05:34 PM
denisond3 denisond3 is offline
Re: 1990 Escort EEC-IV 1.9 L CFI - Cold Start Problem
The most common reason for this would be a sticking "idle air control valve". When they get old, replacement is called for. They cant really be cleaned, as they as still old.
I had a similar problem on my 91LX, even after replacing the i.a.c.v. I put a think piece of steel to increase the idle speed when the i.a.c.v. was at its minimum. It was a tiny chunk of a dual edge razor blade, glued onto the throttle valve 'stop' with permatex gasket maker. Its possible that the throttle valve pivot was worn. The car had over 250k miles on it.
