Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 11-15-2001, 05:12 PM
infintig20 infintig20 is offline
Angry stupid G20 won't start
can anyone help me please???
my 91 G20 won't start!! the plugs are ok, distributor, cap and rotor are ok!!! fuel filter changed, battery ok, injectors ok, fuel pump fuse ok,
fuel pump relay ok!!! i'm stuck!!! I took off the feul line leading
to the engine, cranked it and no gas came out so i replaced the fuel filter and tried it again no gas came out, so i checked the relay and fuse
they were both ok!! i'm thinkin the fuel pump is gone!!! anyone
ever have this problem??? i really don't wanna drop the gas tank to
find out the pump is ok and then put it back up!!
thanks,
desperate to get it started
Old 11-15-2001, 07:32 PM
AznVirus's Avatar
AznVirus AznVirus is offline
Send a message via AIM to AznVirus
have you checked the starter?
1.6 - The Underdog
GA16DE-T Club!
Old 11-15-2001, 07:33 PM
ya the starters fine
Old 11-16-2001, 02:54 AM
T4 Primera T4 Primera is offline
Have someone switch the ignition to on (not cranking over) while you listen near the tank for the pump to build pressure. In my car I can hear it from the drivers seat. If no noise, check the harness/plug to the pump is clean and secure.
Yes, I think this has happened to some others on the forum. I think P10DET has had a fuelpump die on him.
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
Old 11-16-2001, 06:54 AM
P10DET's Avatar
P10DET P10DET is offline
Yepper.
If you removed the fuel line and didn't get cover with fuel, I'm pretty certain your pump is gone. The line should be under quite a lot of pressure.
It's not hard to replace, just a little scary. Disconnect the battery (I forgot to - DOH!). Ground the car. Ground yourself if you really want to be safe. You don't want any sparks with the tank open.
BTW, you don't have to drop the tank. The pump is replaced from inside the car. You have to remove the rear seat and you will find an access plate. Just have patience. Took me about an hour to an hour and a half. I could do it in half the time now.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 11-16-2001, 03:23 PM
BuddhaBoy BuddhaBoy is offline
Hi guys, I am new to this board and I own a 91 G20. I had the same problem as you which the engine would start for a few second then stutters and dies. I tried changing the battery and checking if it was the alternator but it ended up being the fuel pump causing the problem. Your situation was very similar to mine, so i gotta say it was the fuel pump.
Old 11-16-2001, 05:18 PM
Welcome to AF BhuddaBoy
-- Bertrand Russell
Old 11-16-2001, 05:33 PM
frogg's Avatar
frogg frogg is offline
Send a message via AIM to frogg
Originally posted by Everyone
:finger: WELCOME! :finger:
Old 11-16-2001, 09:57 PM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
If it is the fuel pump, like DET said, it's right under your rear seat. It's not like domestic cars where you have to drop the tank, remove gas, and all that other pain in the ass stuff. Good luck with your car.
nightmaR3Z
Old 11-18-2001, 04:11 PM
RYANS RYANS is offline
Send a message via AIM to RYANS
it is your fuel pump. same thing hapened to me. had to replace it
Old 07-26-2005, 05:47 AM
DJ_hoody DJ_hoody is offline
Send a message via MSN to DJ_hoody
Re: stupid G20 won't start
Hi everyone, im having this trouble too, just found this forum , great site btw!!
Im having starting problems, found out when u tap or bang the top of the sender/float unit under the back seats the car starts..bizzare, all i can think is that its either a bad connection or fuel pump is on its way out, i have a spare p10 (g20) at my house for parts, but I havent a clue how to swap them over... p10det can u help plz..
the manual i have doesnt really tell u much...
my car starts sometimes and runs, but sometimes i turn it on and it just stalls then dont work unitl u hit / tap the top of the plastic cap of the float sender unit...
thanx in advance
hoody
Old 07-27-2005, 06:08 AM
does anyone know how to get the fuel pump out, ive just bee struggling for the last hour, and i cant budge it, now im starting to hallucenate from the fumes..lol
