Go Back   Automotive Forums Car Chat > Chevrolet > Cobalt
Old 11-06-2017, 12:01 PM
pradhan.tony@gmail pradhan.tony@gmail is offline
HELP!!! Problem with steering
Hello everyone,
I have an 06 Chevy Cobalt that i bought couple months ago, Just recently, last Friday to be exact, my steering has become an issue. When i was on the freeway, my steering has become hard to turn. However, when i turn the car off, it seems to be the way it is suppose to be. I am pretty sure it is the power steering as mine is an ESP (Electronic Power Steering). I was looking for a reservoir to pour the power steering fluid but I did not find it. This is how I found out that it was electronic. Anyways, I just took my car to a mechanic and he told me that he found 30 different codes that could be the cause. He is not sure what the cause is so he gave me a list of codes. Here they are. P0520, u0101 (Engine), B0081, B1325, B1370, U2103 (Airbag), B0283, B1325, B1480, B2580, B3100, B3109, B3265, U2108, U2111, U2172, (Body Control Module), C0000, C0475, C0895, U2105, U2107 (Power Steering), B1025, B1325, U2100, U2103 (Radio), B3031, B3055, B3060 (Theft Deterrent). Now, is this true? That there could be multiple culprits or just a short that is sending all these fault codes? Or are they trying to rip me off? I read on another post that there is a bulletin and I know there was a recall done for this but ended in 2010. I have done some research and most of it has named the power steering motor as the culprit. All and any responses are appreciated. Thank you.
Old 11-10-2017, 06:54 AM
rhandwor rhandwor is offline
Re: HELP!!! Problem with steering
http://www.ebay.com/itm/272780143224/www.ebay.com
I think this is what you have this used unit should work otherwise proper diagnosis is needed.
Old 11-10-2017, 07:06 AM
http://www.ebay.com/itm/311995298411/www.ebay.com
This type has a tank on the pump.
Old 11-11-2017, 05:50 AM
Tech II Tech II is offline
What you should do, is go to any GM dealer, and give them your VIN number, and ask them to check for any open recalls.....
Otherwise, clear all codes, drive vehicle, and see if the problem recurs again, and what codes are set....
There are a ton of TSB's on this problem and If the wiring checks out, and there is no water leak that is affecting the harness, you probably need a new electric motor...
Old 06-13-2018, 03:55 PM
la1's Avatar
la1 la1 is offline
is your check engine light on
