Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 09-07-2017, 03:38 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
1999 Seville sls cruise control and trunk latch problems
My wife inherited her mom's 97 Seville recently. It just turned over 60k last weekend. The cruise control works on the first drive of the day for about 10 to 20 miles and then quits for the rest of the day.
The other problem is that the automatic trunk latch stops working sometime. I fiddle with both the latch post and the upper latch mechanism for awhile and it will start working again, is there a fix for this?
pic of it here: http://imgur.com/a/dsWdW
Old 09-07-2017, 09:21 PM
Blue Bowtie's Avatar
Registered Offender
Re: 1999 Seville sls cruise control and trunk latch problems
Check the connections in the cruise circuit, including the brake pedal switches (multiples), plugs and connectors, and the center brake lamp - The cruise will drop out if the center brake lamp circuit has resistance which is too high. If an LED lamp was installed in the center brake lamp, replace it with a stock incandescent.
Does the trunk latch have a remote release as well as a motorized pull-down, or only the release?
Old 09-08-2017, 01:21 PM
ericn1300's Avatar
AF Premium User
it has both the remote release an the motorized pull down
Old 09-08-2017, 08:55 PM
Registered Offender
Is the problem in the release function or the closure?
Old 09-09-2017, 05:51 PM
ericn1300's Avatar
AF Premium User
The problem is during closure. You can manually depress the deck lid all the way but the auto pull down sequence does not begin and the latch will not latch.
Old 09-09-2017, 07:56 PM
Registered Offender
It is likely that at some time someone slammed the trunk lid not knowing it was an auto pull-down and broke the switch/plunger in the mechanism. It's pretty common. Sometimes the nylon gear also suffers damage.
http://www.partsgeek.com/gvxs8v5-cad...ll+Down+Switch
The Following User Says Thank You to Blue Bowtie For This Useful Post:
ericn1300 (09-10-2017)
