Old 08-24-2017, 04:20 PM
mb7733 mb7733 is offline
1992 Buick lesabre no power to blower A/C blower
Manual A/C
Replaced blower Dec, made a racket and installed new one, worked fine, but apparently the male end of the new blower was bent, well a couple months later the cable finally shorted out the connector completely causing it to work intermittently before i discovered the issue.
So i replaced the blower and used butt plugs to wire a new connector
but did not cut on, no power to the connector.
I even replaced the resistor under the Fuse box near the fire wall thinking this would work.
After a couple more days i redid the wiring of the connector and it finally cut on. But only intermittently. It would go days without working then work all of a sudden for a couple days. then it became a couple days off a couple hrs on.
Now when i turn the key before i start the car if the a/c is on the blower cuts on for a sec then stops
I noticed that some times the blower would not cut on unless i had been driving down the road for a few mins. Other times it cut on from start in the morning. Could there be an overheat override?
Fuses are all good, i have not checked if there is power going to the fuse.
If i am going down the road fast enough i can feel the cold air that the compressor is producing so i don't think thats the problem
Old 08-24-2017, 06:12 PM
Blue Bowtie's Avatar
Registered Offender
Re: 1992 Buick lesabre no power to blower A/C blower
Have you checked the blower relay? The blower requires it for all speeds, not just high. I believe the '92 has the relay in the array along the top of the cowl in the engine compartment.
