Go Back   Automotive Forums Car Chat > Buick > General Discussion
Old 08-20-2017, 01:20 PM
Trio3b Trio3b is offline
Send a message via AIM to Trio3b Send a message via Yahoo to Trio3b
1997 GM 3.8L Factory Manual specs wrong?
Unbelievable but....
Prepping to replace LIM gasket and Upper plenum and gasket on 1997 Buick LeSabre due to coolant ingesting into engine. I think I've caught it early so we're ok but ordered the GM factory manuals off ebay. These Are NOT Haynes, Chilton or on DVD but appear to be authentic GM manuals very thick in 2 volumes with
"D. Hamilton Chevy-Olds in Redmond Oregon" stamped on the side so have no reason to believe they are not authentic. I also have two very thick GM manuals for a 1997 Chevy C1500 that are of the same format and look identical in layout so again the GM H body manuals seem legit.
Was reading fastener torque specs and LIM show 89in lb = 7.4 ft lb and upper intake shows 11 ft.lb.( I'm looking at it right now) This makes no sense. Every one online indicates the torque specs are
LIM = 11 ft lb
UIM = 7 ft lb.
Guess the factory manual got it wrong. Gaaad! Come on guys!!
1. Any confirmation on correct specs?
2. Manual calls for threadlocker and online guys call for PTFE thread sealer
3. Any advice on RockAuto Dorman vs ADP upper manifold
4. Confirmation of Aluminum frame LIM gaskets preferred over plastic
5. Someone suggested just buy the 2nd version gaskets WITH alignment pin and just cut the pin off if not needed. Otherwise have to pull manifolds, check which version, then order and leave stuff apart for a week while new parts are shipped.
Thanks
Old 08-20-2017, 02:43 PM
Blue Bowtie's Avatar
Registered Offender
Re: 1997 GM 3.8L Factory Manual specs wrong?
It may be a typographical error, or it may be that the upgraded gaskets have a different specification. I've used the FelPro MS98014T and complete Dorman 615-180 upper kit without failure. The lowers are torqued to 150 in/lb in four rounds of following the sequence, with threads cleaned/chased and PST (Loctite 592 or Permatex 565) sealant applied to prevent thread wicking on the LIM bolts. The uppers are torqued to 85 in/lb in four rounds through the sequence.
The Following User Says Thank You to Blue Bowtie For This Useful Post:
Trio3b (08-22-2017)
Old 08-21-2017, 01:22 PM
Tech II Tech II is offline
Yeah, off the top of my head, I don't remember the lower intake specs......but I do remember that black upper plenum was 89 inch pounds...
Old 08-22-2017, 10:53 PM
Looks like your specs are correct. Will go with those. Did use a Dorman on a 93 Park Ave yrs ago and seemed to be ok however reports on the ADP claim it seems sturdier. I'm doing 2 engines so may purchase one of each.
Thanks
